psuperti
Hi all, the original module and new module did not make a difference.
The python remote start hasn't worked in 4 years.
Which one is the fuel pump fuse?
Last night I was able to rule out the kenwood amplifier cable and it's capacitor. I move all the positive battery cables to an isolator switch.
So to clarify things. I replaced the battery 2 weeks ago. I noticed the car was dying if not driven for 2 days. No change in gadget add ons since 2014.And 3 days ago driving home the car s electric power turned of an on by itself on two occasions. Engine runningI checked the terminals they seemed ok. I put the trinkle charge on it. Next morning it wouldn't start. I think it was a bad battery connection. Because as I mentioned all the power went off. The battery, alternator tested fine. The only visual problem were a burned out fuse on the module, week souter on the module and a stripped negative battery terminal. I started by getting the Optima Red top out and trying another. Then the module and last the terminals, now it won't turn off.
Will not start, will not switch off, we have various symptoms spread over three thread.
Combine them all in one post please I am confused.
Pulse module and ignition switch come to mind when I analyze what
I understand.
