Old May 14, 2016 | 06:23 PM
onehundred80
Default Re: Need a Superchager clutch or whole supercharger ASAP!!
Originally Posted by SeanOldaker
My supercharger clutch went out ive tested everything and i know its the clutch, so i need a new supercharger as the clutch is a part of the housing, ive been told by some that i can remove the shims and drive the supercharger full time with out the clutch but im afraid ill mess up the motor or ecu, anyways if someone has a used supercharger id love to do a core exchange or something as im very tight on money but i need my car back up and running ASAP!
I do not understand what has gone wrong with your SC, removing shims will not fix it if the magnet failed. If it is the pulley assembly itself then there is less of a problem.
