Old May 15, 2016 | 08:12 PM
Mrmiata's Avatar
Mrmiata
Default Re: Need fix Steering locked and key locked in ignition
Note: When it's locked up.. you get to drill the pin out by the steering column.. when you get to the point your ready to work on it.. use computer duster (compressed air inverted) to see if it will let you get that much needed key turn on the switch.. seems "freezing" the assembly might save you from drilling.. "new theory" we need to confirm a couple times here...
