Old May 20, 2016 | 05:11 PM
onehundred80
Default Re: Help a girl out :)
Originally Posted by X_fire_chic
Thanks I found the group on FB. Requested to join.
UPDATE: I changed the spark plugs, started the car ran perfect. Changed the CPS started the car ran fine. Drove 150 miles the next day no issues. THEN.....drove 1 mile to buy coffee, I get back to my car start it up and it is jumping like two rabbits going at it!
Now what? Are y'all saying that fixing the RCM will get rid of this problem?
The P0410 problem will not cause this problem. Are you sure there are no other codes. The RCM can cause intermittent stop and go situations, but they do not fit your pattern, but getting the three common soldered connections resoldered would not hurt.
I am leaning toward fuel filter/fuel pump problems, the pressure regulator may be acting erratically, I'll check some more here. If I recall Valk had similar erratic behaviour.
Are the battery cables clean and tight?
