Old May 21, 2016 | 01:35 PM
X_fire_chic's Avatar
X_fire_chic
Default Re: Help a girl out :)
The P0410 problem will not cause this problem. Are you sure there are no other codes. The RCM can cause intermittent stop and go situations, but they do not fit your pattern, but getting the three common soldered connections resoldered would not hurt.
I am leaning toward fuel filter/fuel pump problems, the pressure regulator may be acting erratically, I'll check some more here. If I recall Valk had similar erratic behaviour.
Are the battery cables clean and tight?
Thanks for the feedback. My battery cables are clean and tight. I did not see any other codes showing up on my ECU.
Do you know if changing the fuel filter is pricey or difficult to fix?
