Old May 23, 2016 | 07:51 PM
dedwards0323
Default Re: Same issues as others NO START
Originally Posted by csvir
I have a 2006 Crossfire Roadster with a manual and 41k on it. Took it out of storage connected the battery fired right up drove it about 10 miles to the gas station then started it and parked it in the garage and that is where she sits. Two cranks starts then kills and starter won't engage multiple times when I take the neg off to reset. I have replaced the battery since it was original, both key fobs still work, soldered the 3 spots on the RCM and the alarm still activates with the fobs so think the SKREEM is working. Oh and I did push it forward a few feet and same result. What would you guys recommend for my next go around? Thanks!!
RCM repair could be bad solder joints anywhere; not just the three that typically give problems. DJ fixed mine; re-soldered multiple joints on the RCM & had to replace 2 bad relays. Works like a champ now! And the horn works like it should!
