Old May 23, 2016 | 08:14 PM
Mrmiata's Avatar
Mrmiata
Default Re: Same issues as others NO START
Have to agree with Mark.. and rumor has it DON'T do the battery thing 10 times.. AKA 30 attempts and fails at starting.. the ECU is reported to pull a mission impossible.. IE.. self destruct. At this point.. I'd say disconnect battery for a couple hours.. with it still loose go through the motions of starting it.. fully discharges everything.. then give it another try.. If it hits then dies.. you don't need to give it "another" chance to start and die.
And just to tag another base here.. no fob case swap.. or dropped fob that came apart.. or anything along that line right? Extra key to try the start with?
