Old Jun 4, 2016 | 09:26 PM
BibaResto's Avatar
BibaResto
Default Need Information on Speed Activated Spoiler
pizzaguy, with the engine running there is continuous 13.5 volts to the left side limit switch. Upon completion of it opening, there is close to 0 volts. Closing, it immediately goes back to 13.5 volts. They're simply on/off switches. That is unless they're tied into the BCM to activate the spoiler at speed.
I've tested it twice and am sure of these figures. I used needles in each of the left side limit switch wires.
The raised plastic edges on the large gear are of course staggered from side-to-side. I'm unable to see but I assume the right side is on a raised section when down.
Now do you feel a regular old 10 or 20 amp double throw/double switch will work?
Another question: on the schematic you included, for the motor (bottom left) it refers to them as being Rear Spoiler Driver up, the other side down. What is a 'Driver' in BCM code?
