Old Jun 7, 2016 | 01:26 PM
BibaResto's Avatar
BibaResto
Default Need Information on Speed Activated Spoiler
Okay another crude one, but yes, there is a problem - except on the left, down side.
The gray + wire activates the up side and the black stops it. Unfortunately on the way down I need for the black wire to switch places.
Id sure like to know how the original switch with two wires handles this.
I doubt much if what I'm about to suggest even exists. That being a rotary switch set up in the order of function. Somewhere the juice for the motor needs to be factored in. But rotating the switch from the static position to the right activates the gray/black. Turn switch from static to the left pair and it goes down.
It would seem to me that the motor gets its reversal info from the limit switches...but sprite63's set-up only uses the two motor contacts.
I'll certainly bow out of this thread if it is felt that I'm hindering this discussion/thread.
