Old Jun 19, 2016 | 10:00 AM
SuperD500's Avatar
SuperD500
Default Re: Weisslicht LED Headlights?
Which builds up the most heat during operation a regular H7 or the LED version? Our H7 bulbs are sealed in the housing, the heat produced is in the front of it.
If LED is more efficient then it has to produce less heat for the same light output. With the heat produced in the front of the housing or less heat in the rear of it which is best, I cannot say myself.
You certainly want to keep them sealed away from moisture as they supposedly are now.
The above Weisslicht seem to be small enough to fit in the headlight unit, closed with cap. At least, that's what they advertise
