Old Jul 1, 2016 | 12:42 AM
  #977 (permalink)
Red Runner's Avatar
Red Runner
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Is this something pep boys can fix, or do I need to take it to the dealer?
The answer is NO! & NO! The last place you want to go is the Stealership and Pep Boys can't help you. You need to go to Post #1 & read the PDF for Sticky Key Fix. This is something you can do yourself. Since you can't turn the key it won't be EZ. There are some possible temporary fixes that are on this forum. ie: Lube the lock cylinder, use some spray cool down lubricant.
