Old Jul 2, 2016 | 11:46 AM
  #71 (permalink)
Merman5148's Avatar
Merman5148
Default Re: Converting from AutoStick to manual-looking shift boot
Originally Posted by Beaner
I took pics of mine a few minuets ago to show how to install a shift boot on an automatic.
- Remove shift *** and the plastic peices around the gear selection display
- Put the plastic trim piece in bottom of shift boot. Make sure it is centered how you want it and that be careful it is very brakeable
- Push the shift boot threw the center and set the shift *** inside
- Put the bottom cap on the shifter before you push the *** on. This is very important. be careful when pushing it on so that the cap does not get damaged
- Make sure there is material is all they around and able to get in the cap. If there is too much you will never be able to screw it on so what I had in the previous pic is good enough
- Put the car in neutral and jently push the ring down makeing sure there is just enough material tucked under to hide the edges.
- push it down tight and there you go. Put the car in park. Done
- The switch with the W and S is still useable, you can feel for it right threw the leather and switch it at any time.
Ok so i have two questions one how do u take the original shifter off do u unskrew it or do you pull it off and second how do u take the trims off. My idea is to make a crown royal shift boot
