jen111
Thanks Pizzaguy
One day it just did not start nothing at all not even a click. AA diagnostics showed immobiliser fault. It then started ! Same thing happened and had to get it low loaded to a garage. Now seems very rarely starts and their diagnostic machine showed it was this part that was at fault. They are asking £1500 t supply and fit and cannot get the part from the Uk.
Thanks Jenny
I doubt that the immobilizer is at fault. Rather it seems to be the RCM or the CPS. As it is intermittent it could be either. When checked it should have a code set, if so what was it?
If it is one of these problems the fix is no cost or $50. Get the code read and let us know, maybe you are being taken advantage of, maybe not. Get that code.
