Old Jul 13, 2016 | 06:51 PM
onehundred80
Default Re: Help diagnosing No-Start - Electrical? But not RCM or CPS
Originally Posted by Kingdav1954
.........180 would the clutch interlock switch cause it to lose all power like he has expressed? I don't have any experience with the 6 speed my Roadster is an automatic.
I do not know, just an idea, I'd check to see if there was any power going to the starter, maybe it is toast and shorting. Maybe there is a poor cable to battery terminal, loose connection, corroded cable terminal. Poor ground as mentioned. Any codes set?
Where did the AAA man make ground to the chassis, did he use the battery or another ground source like he is supposed to? If he did that may point to your problem, a bad ground.
I had a similar problem once, I had forgot to tighten the terminal clamp nut, suddenly, no start and no power anywhere.
