onehundred80
The complete set of components is required, what you have, the SKREEM and the PCM I believe. There is a code in the SKREEM that matches the chip in the keys and PCM.
As stated it can be fixed just by removing a little spring and pin, I'm assuming this is an '04 to '06 model. If not we will think again.
Yes it's an 04... It came with what I thought was all the parts needed. Guess it's money wasted and hopefully I can figure it out. I can't tell exactly where this pin is in the .pdf I look all over around the ignition and see no shiny pin.... Once I locate that just drill it or cut it off and the ignition assembly should pull out? Or...
