Old Jul 27, 2016 | 07:02 PM
  #56 (permalink)
onehundred80
Default Re: steering / ignition locking
Originally Posted by DarksideXF
Yes it's an 04... It came with what I thought was all the parts needed. Guess it's money wasted and hopefully I can figure it out. I can't tell exactly where this pin is in the .pdf I look all over around the ignition and see no shiny pin.... Once I locate that just drill it or cut it off and the ignition assembly should pull out? Or...
The pin and spring you remove is hidden under that little plate you have to remove. The pin you have to grind/drill off is as George says is hidden by the trim under the steering wheel which you pullback. It is all explained in the PDF quite well. Good luck.
