Padgett
How the ^&&% do you remove the battery ? Does the engine need to come out first or is there a special tool ?
Mine (2011) has died and I have a replacement AGM on order but need to get the old one out. How ?! YWTK
If you have no handles then you could use one of those straps that pick up the battery by fitting on the battery posts.
In your case you could use a Sawzall and a hose to wash away the acid.
