Old Jul 31, 2016 | 08:22 PM
  #59 (permalink)
onehundred80
Default Re: steering / ignition locking
Originally Posted by newestguy007
I'm trying to fix this myself, however I took the panel off , the transponder ring unhooked , and I have no idea where the location is at, can anyone take a picture and show me??? Thanks in advance
There is a complete article on how to fix this problem. CLICK
The photo shown by PG is only a part of it and what he says is a bit misleading. You loosen that bolt and then push the trim panel on the left over and then pin is underneath. You then grind the pin away with a Dremel or drill it off which is the trickiest way to do it.
It all depends if your key is locked in the ignition or not.
Look at the sticky ignition fix. You would not be asking this question if you had read it.
