Thread: Warning Lights
Old Aug 14, 2016 | 05:02 PM
GraphiteGhost
Default Re: Warning Lights
They can be assumed to be idiot lights but once in a while they will save a life by showing a partially flat tire that could rapidly escalate into a rapid tire failure.
In some jurisdictions removing the sensors would mean an immediate failure of the safety test if one was required. This would be because any such safety feature should remain operable.
The main safety device in any vehicle is the DRIVER. You cannot rely on a device to protect yourself. TPMS will not help in a catastrophic failure, and a good feel of the feedback from the steering wheel tells a DRIVER who is aware that a wheel (or something else) is not right. A couple examples, I had a right front blowout on I-10 eastbound, in the left lane passing two tractor trailers going in excess of the speed limit. Since my two hands were on the wheel, I was able to finish passing the trucks (I was almost past the front one), then as the trucks slowed I pulled right, they pulled left, I pulled over onto the dirt off the asphalt shoulder. catastrophic failure, no-one hurt (except a right front rim). Second example, I put my two rear studded snow tires/wheels on my 72 Fury III and headed home from the air base in SD, to our home in Piedmont. The trip was 97% interstate, about 3/4 way home I felt car becoming squirrely. Pulled over, found both snow tires very low. Turns out they were stored in landlords basement next to a large electric motor, and the ozone from the motor broke down the rubber in the mounted tire/rim set over the preceding summer (I asked him to store them he did). Point is, the driver should not rely on a light to know his/her tires are correct.
HeII, gadgets are nice, but people should be a lot more aware of their surroundings. Especially when it comes to their safety and operation of their vehicles. This is one area I do not rely on some gadget. It is also good to be in a state where the nanny mongers are not in a majority.
