Re: Under da hood
Kamilspider, If you are using the MB PN 1120900501 air cleaner on a stock NA XF. The OEM inlet tubes fit the air cleaner. The only time there would be a problem is if you do the throttle body mod then you would not be using this air cleaner. This air cleaner is a perfect fit.
