Thread: Under da hood
Old Aug 25, 2016 | 07:45 AM
onehundred80
Default Re: Under da hood
Originally Posted by Red Runner
Kamilspider, tried to tell you to buy the A 112 090 05 01 that is a perfect fit for the NA XF. You now have an air cleaner that doesn't fit your throttle body.
That is not true, the cover fits the MAF housing and it fits the OEM one or the 74mm one no problem. The part number you give is the SLK320 housing and if you are going to change the TB and MAF housing some time the cover he has is the correct one.
