Old Aug 27, 2016 | 08:57 AM
onehundred80
Default Re: Speed Warning Chime at 75mph
Originally Posted by Mightywing7
Gang:
My 2006 SRT-6 has started to produce a warning chime (same buzzer sound used for seatbelt warning) whenever I hit 75mph or greater. The warning will continue to chime as long as I stay above that speed, but will stop once I go 74mph or slower. I have searched throughout this forum as well as other sites, but to no avail. Disabling the seatbelt warning chime does not eliminate the 75mph or greater speed chime. Also, there is no correlation if a passenger is present/seated or not (if anyone was thinking if it could be an passenger airbag warning chime if there is one). Any thoughts?? Thanks!!
There is a post that says that the chime can be set at this speed to warn you that you have exceeded this speed. It says it must be reset at the dealer, I do not know if this is true.
I think that there have been posts that say this is a speed sensor problem and the cruise control will cut out if it is being used.
Other than that I have no idea, sorry.
