Old Sep 1, 2016 | 11:06 PM
Billto's Avatar
Billto
Default Re: 722.6 Transmission
[QUOTE=cudaman;873429]Bringing back an old thread. I am now experiencing this very same issue as BillTo. Low mileage SRT6. Sort of comes and goes, mostly when it's host outside. Getting occasional P0715 pending codes. Let it cool off and it's just fine the next day or after a couple of hours. Doesn't appear to be leaking. Will check the fluid level when time permits. Everything around the area looks dry unless it's leaking internally and lowering fluid pressure under load/heat conditions. Wondering if BillTo finally did the conductor plate and to what result.
Would like to just "do it once" and be done with it after getting the right parts ahead of time. Also a very low miles
