Old Sep 3, 2016 | 04:52 PM
onehundred80
Default Re: Speed Warning Chime at 75 mph
Or didn't miss a step? I have no idea how they program the TPMS calibration, but wonder why a 'speed' alarm would be part of the train of commands to set a TPMS system up. I would appreciate anyone who knows the TPMS calibration procedure (with the system in a stealership) would chime in to clear this setup for me?
A post from December 2012 by Crossfireone
Your beeping over 75 mph is usually accidently turned on after your car is in for service & had a DRBIII hooked into the system. It falls under the (customer preference) portion of the DRBIII & is either on or turned off by the tech. Theres no speed choice avail. other than on at 75 mph or not on at all. The only way to remove your beep is to have a DRBIII hooked up again & the choice turned off. Simple procedure but costly if you have to take it to someone who has this tool. We live in diff. parts of the country or I would be glad to turn it off for you. Hope this helps.
