bbsrt6
Morph: so u had the same symptoms I was describing? I have the nw 65mm pulley saver kit on mine with the belt that rob included in the kit. U had a single loud chirp followed by a great shove in torque?
Not so much of great shove of torque, but had chirp even when car would change gears between first and second gear it would chirp, i have 65mm but no psk, but I had to change pullies, idler, guide, belt tensioner, car has only 66,750 miles
Once I put new belt from dealer, and changed front end links it went away now. It was only making chirp below 2000
Hope this helps.
