onehundred80
You originally state that the gap was just over .20 mm maybe .22 mm and when you added a 1.00 mm shim it was just under .30 mm maybe .28 mm. From those figures we can calculate that the gap shrank from .22 mm to (.28 mm - 1.00 mm) = .04 mm which is .0015".
For sure, measuring in that area is sketchy at best, but if the measurements are close, it looks like the gap is now .06mm bigger than it was after I first installed the pulley, and again, as you said, it appears to have "shrunk" .04mm from the initial installation.
Like you said, measurements that incremental are of little consequence, but I did it because I didnt like having the gap being smaller than Code 3's spec's after the pulley "settled in". I assume there cant be a gap of less than .2mm because of heat expansion, or pulley spring fatigue, whether the SC clutch spins freely or not.
As I said, my SC clutch DID spin nicely when the car was off, and even with the shorter gap, I could stop the SC clutch with my bare hand
**when the engine was running**.
**NOTE!!**-- I DO NOT recommended trying to stop the SC clutch while the engine is running with a bare hand!!
I should NOT have tried doing that!!).
