onehundred80
I think that the instrument panel lights for the indicators are made to flash using a flasher mounted on the printed circuit behind the instrument cluster.
The flasher for the lights is in the BCM.
I got this circuit from a post by Ala_xfire. CLICK
I think for now anyway.
Confused.
So, the way I read that circuit diagram, if the Hazard Switch Assembly, which is mounted in the Console Switch Group, goes bad, none of the turn signals work, which includes the flasher function itself.
That would explain the original condition identified by
mavxfire.
Does the circuit diagram also indicate that the interior lights are powered up thru the Hazard Switch Assembly? If they are, wonder if they are also not working on the car?
