Thread: Intake System
Old Sep 23, 2016 | 01:21 AM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Intake System
Originally Posted by Billy22Bob
BB - You've stuck with the 74mm Stock Pulley? - just checking as there isn't any in your sign..
~19psi (sea level) ?
Any record of g/s air at red line from the ECU?
Yes, Stock S/C pulley. I did replace the smaller idler pulley that came with the crank pulley kit with the OEM idler and installed a larger serpentine belt to compensate.
7 years and 70K miles later, I still run the same setup with no issues.
With this setup, I max out at 21 PSI at sea level @ 80F
