Old Sep 24, 2016 | 09:30 AM
onehundred80
Default Re: Camshaft position sensor: DIY replacement with pics
Originally Posted by Steve PD
Re: replaced CPS, did the RCM repair, STILL shutting off.
HELP Crossfire Not running
NO START /FAN Running
Hi Guys ,
See a lot of iHistory nfo .. going back last few years
On No Start issues ..
Can i conclude that if I have still no start issues after
FIX 1 = RCM , resoldering
FIX 2 = CPS , Replacing with New Bosch cps
FIX 3 ?
That next step is to replace
ECR Engine Control relay ( P/N ??##### TBA ? please )
FIX 4 ?
Replace entire RCM if FIX 3 dosent work ? ( Is it the Merc K70 ref ?)
FIX 5 ?
Cam shaft sensor ?
HEADLIGHT opaque /sun damage ?
Repair or replace?
Also can anyone help on New Headlight Plastic , replacements ?
Cheers Steve UK Sept 2016
PS love the Shape by Karmann , not the Merc elec,s
But getting ready to scrape it soon if RCM/or ECR doesn’t fix it
Fix #3 looks to be your best bet, failing that then fix#4 as the relay is inside the RCM (K70).
Tighed1 replaces the relay, fixes the bad soldering and whatever else is needed.
Fix #3 is the cheapest unless you can get a cheap RCM.
You did good on your research using the Search feature, not many do.
Repair the headlight with a kit made for the job, a bit of wok to do correctly but as you cannot replace just the lens you have no other option. Used ones cost good bucks and new ones go from $6oo.
Last edited by onehundred80; Sep 24, 2016 at 11:34 PM. Reason: Headlight info added
