Re: Passenger side and trunk wont unlock
I have never owned a Coupe. I do know the Roadsters have an emergency release that you can access by removing the driver's side tag/license plate light -you take a wire coat hanger, form a hook in one end, pass it in about 8 inches and fish around and grab the emergency release cable and pull - trunk pops open!
Iv'e tried this as a test and it does work!
You then remove all those little black button-things in the trunk area and the trim comes out. The pump/module in a roadster is in the wheel well ahead of the tail light assembly. YOu can raise the decklid as if you were putting the top up/down and see the thing down in the well but you cant GET to it unless you tear the trim out of the trunk.
As to Copues, I've never owned one, but it is said that it is under the floor trim, kinda off to the passenger side. It IS in there, I guarantee it - dont' say it is not there, it IS there. Ya just gotta dig for it.
Others who own coupes will maybe be more help
ALSO, if you are going to try to work on the car yourself, you are wasting your time without the service manual - all of this is detailed in there. You can get an electronic copy in the Tech AReas of this forum. Look for "Crossfire Documentation Collection". The 04 manual is COUPES ONLY. The 05 SRT manual is ALL CARS.
