Old Sep 27, 2016 | 04:50 PM
onehundred80
Default Re: radio ignoring all controls
Originally Posted by grahammrobert
Hi. First forum posting, so wish me luck. A couple of days ago the radio display showed a random selection of angled lines, but powered on and worked ok. Next time we used the car the radio came on with the ignition, but did not respond to any of the buttons, volume, anything. So it is now fixed on one station at a set volume that we can not change and we can not switch it off. Okay until it loses the radio signal, at which point we are forced to listen to the crackling noise. Help please. It's a 2006 Crossfire with the standard radio (as far as I'm aware).
Response by Pizzaguy.
There are two fuses for the radio - pull them both. (Sorry, but the exact fuse varies by year, I found this out the hard way this summer). Both fuses are in the undershood fuse box, driver's side. Leave them out 15 seconds or more.
Alternatively, disconnect the battery ground cable for 1/2 minute.
When you power back up, it should restore it's brains. If not, it is done for - sorry.
(This will go in the Index of Crossfire problems.)
