Old Oct 12, 2016 | 07:05 PM
pizzaguy
Default Re: BAS ESP Light comes on intermittently
Originally Posted by waldig
Pizza, I get the light now and then and it goes out now and then, does that fit your thinking on the relay module????? I soldered the board in mine but could pull it and clean contacts on relay points if you believe that is the issue. Thanks WDY
I was really referring to the P0401 code.
But now that you mention it, I do wonder what the effect of the Traction Control relay being pitted/bad would be?
Looking in the wiring diagrams......
Ok, the module has battery feed from two 40 amp fuses, but then it gets ignition-switched power the the relay on the RCM. This realy DOES NOT only close at 'certain times', but is closed anytime the ignition is on. THEREFORE, I'd think that loosing this power would be an "alarmed" condition.
This makes me answer "yes" to your question.
But we can test this theory:
Get into your RCM and yank Fuse 1 (15 amp, feeds only the Traction Control Relay). I'd bet you that pulling that fuse and starting (or at least DRIVING) the car will set off the light. If it does, then I'd clean up that relay or change it. If it does NOT result in the light coming on, well, we must look elsewhere.
I think our friend in Arizona provided this photo, if so, I'd sure trust it:
