Re: H7 high beam watts
Thanks, I have been told that HIDs do not like cycling on and off and are best for low beams. I was told not to use them in the high beam because the cycling is bad for them!
So the halogens are all thats available for high beams. I am sure the LEDs will be great when they are bright enough for really long range. I know the halogens get hot, that is why you really need metal and glass units to handle the heat with 16 gauge wire and relays for power. So you say that HIDS will handle the frequent off and on use in the high beam position?
