lightninle
I have the same problem as 'Viper3D' only i went 3 miles then it died. it started 20 minutes later and i drove it home, 3 miles, no problem. today i just moved it 20 feet and it died, put my OBD2 meter on it and it showed no faults! but started 20 minutes later.... would that be the RCM?
Does the engine always turn over when you try to start it after it dies ?
If so, then most likely the CPS, if not, then the RCM.
