Old Nov 16, 2016 | 02:18 PM
csteve0355's Avatar
csteve0355
Default Re: New headliner, pretty easy to replace.
Originally Posted by Natemo
Background: new member; I just got a 2005 Crossfire Coupe Limited with just over 30K miles. I'm very happy with car but the headliner is drooping on the driver's side. I debated just trying to get the liner loose on that side and spray adhesive into it but it seems like removing the whole headliner isn't that hard. No one has mentioned whether the rubber window seal needs to be removed. Is that necessary? More pictures of the process would be great! Thanks in advance for your help!
Natemo
The rubber window seals are not removed. I found that removing the whole glove box door made the removal and install a snap.
Also remove the b pillar trim before removing the large grey sails behind the quarter windows. Start by moving the seat belt to the side where it comes out of the black trim under the quarter window - you will see a gold colored screw remove this first - then start lifting the black trim from the front it is held on with clips that are close to the quarter window.
