Bump in the trunk. Annoying rattle
Not sure how many of you have actual subwoofers in the trunk, I have one 10" in a ported box that causes a hellacious rattle from the latch mechanism. I know for certain that it's not the problem where you wrap it with tape because I've already fixed that. So I took the trim cover off of the hatch lid and found a small plastic piece that I assume is a part of the handle mechanism that has quite a bit of movement. Is this normal or is there something broken? I would like to find a fix because it sounds like hell every time the bass hits.
