Old Dec 4, 2016 | 07:47 PM
onehundred80
Default Re: Mystery No Start, Same Symptom - New Problem??
Originally Posted by Mr. PVD
Sorry for the delay, busy day today.
Thanks onehundred80 for the procedure. I went through it just as it said and I got the same symptom - crank, run for half a second, and off for a total of three times. I'm figuring the SKREEM is okay since my key fobs lock and unlock the car. Any other ideas I could try?
Thanks again!
Eric
The symptoms definitely point to the SKREEM, but is foes more than allow the car to start so the key issue may not be relevant.
You replaced the SKREEM did you not reinstall the halo around the ignition properly or maybe it got damaged. If it is not working you will get the three start and no go situation.
The SKREEM must be programmed to the car, you cannot just put any module in. It is a security item, so what security is there if any one can be used and have it work.
