Old Dec 5, 2016 | 08:39 AM
dedwards0323
Default Re: Strange debris in cabin filter cover
I changed my cabin filter today and found some strange debris in the bottom of the filter cover. None of this was found in the old filter which is strange, it was just lying inside as shown in the photo.
They look like paint chips, not plastic wiring insulation.
I also made an old thread by mach2plus about the filter change into a PDF, I added newer photos and edited the original text. CLICK
So I remembered that I had a new blower/motor assembly out in my XFire spare parts stash. Went to look at it to see if I could pinpoint a source of the debris. Turns out the top of the stator lamination is painted green on the spare assembly. And the color shade is a very close match to what you shared with us in your photo above. So the "paint chips" you're referring to probably are exactly that. Exposure to environmental conditions over time could be causing the paint to flake off the lamination in the motor. Might be an initial indication that motor entered a failure mode and may need changing down the road. My $0.02 USD.
I've attached an image to show what I saw. Hope this helps.
