Old Dec 8, 2016 | 08:38 AM
zip439's Avatar
zip439
Default Re: How to replace grilles?
Originally Posted by coryforman
They came from Canada actually, the brand is APS I believe, don't quote me on that.
The instructions say something about them clamping onto the existing ones and it gives me bolts and all that... I just have no idea what to do. Do I take the old ones out and then attach the new ones to them? Can I just attach them somehow without taking the old ones out? How do I take the old ones out? The instructions suck!
The OEM lower grills pivot from the center of the car. Look at the outward end and you will see a hole in which you can insert a flat blade screw driver; with the screw drive press the tab of the grill outward and that end of the grill unsnaps from the car. There are two "L" shaped ends on the inboard end of the grill; the grill will pivot out and the two "L' shaped tabs will easily release. The grill on the drivers side also has the outside air temperature sensor attached. Be careful to release that so you do not damage it while removing the grill.
