Thread: Headlight bulbs
Old Dec 10, 2016 | 08:20 PM
romanylife's Avatar
romanylife
Default Re: Headlight bulbs
Just be super sure you align the tab on the bulbs correctly. The low and high beam bulbs are 180 degrees apart when placing them into the housing to match the tabs. If they are not seated correctly, you'll never be happy with the light pattern. So, one bulb tab goes north, the other south (in each housing). The other side is the same setup, one goes north, the other south (tab orientation).
Thank you!
