Old Dec 11, 2016 | 05:17 PM
onehundred80
Default Re: Huge drain of the battery from the fuse 1 of the RCM
Originally Posted by matcail
Hi !
I have a huge drain issue with my crossfire 05. The battery is dead if I don't use it for about 1-2 days.
Therefore I used a mutlimeter to look at the drain and I removed all the fuses (from the Engine Compartment, the Relay Control Module and the Interior box). I appears that the fuse #1 from the Relay Control Module is draining 500 mA (see pictures below). I have seen that a ~35 mA drain is normal, so only with this fuse my battery is discharging !
I don't know if it has a link but I have an issue with my cruse control which is not working. I have been to a dealer to make a diagnostic and they told me that my front left speed sensor is not working. I then changed this sensor by myself but the cruse control is still not working. As apparently this fuse #1 is for the traction system, can the issue with the cruse control be linked to my crazy drain ?
Thanks in advance for your help !
Don't hesitate if you need more information =)
Mathieu
Without the gap between the two pictures, I first thought what the heck is the coolant reservoir doing where the battery goes.
