Old Dec 12, 2016 | 08:28 AM
matcail's Avatar
matcail
Default Re: Huge drain of the battery from the fuse 1 of the RCM
Since +12 only goes through F1, then the contacts on the traction system relay, I would have to think that the contacts have become welded in the closed position :
Thanks for the answer =) it would make sense yes based on the diagram. How could I check and/or fix that ?
Waldig, yes the battery is low as I can't fully charge the battery after it goes dead ! ^^
Thank you guys
