Old Dec 12, 2016 | 06:32 PM
matcail's Avatar
matcail
Default Re: Huge drain of the battery from the fuse 1 of the RCM
You can check it by removing the cover on the RCM and just look at the relay contacts :
RCM relays
So indeed...my relay was blocked by someone before ! (see picture below). You're awesome guys for founding that =)
Removing the papers, the drain was then going down and looks way better (even if I still have some coming from the fuse #9 but I will see that later).
However it then created another issue, since the brake pad warming came on now (see picture). What should I do for that ? Could that be linked to my speed sensor issue with the cruse control ?
Thanks a lot !
