Old Dec 20, 2016 | 08:26 AM
onehundred80
Default Re: Headlight Adjustment
Originally Posted by Salty Dawgs
Thank you all for your information! With the help of a block of wood, and some effort to pull the bumper cover away....the reluctant headlamp assembly finally came out. Once I was able to clearly see into the bays where the lamps live, it became obvious that there is an adjuster screw that independently moves the inner (high beam) lamp carrier. A 6 mm socket on a screwdriver type handle allows adjustment. So, back went the headlamp assembly, X-Fire down on the ground and ready to move outside. I had to wait 3 days for winds and snow to ease up a bit, before moving the vehicle outside at night to where alignment could be carried out on the garage door. Fifteen minutes of turning the major adjuster, and then the inner adjust brought all to near perfection! I've tried to attach a photo, and hope that it comes through OK.
Many thanks to all.....
Ted
It should be noted that the picture shown is upside down, the screw is actually at the top.
Using the yellow icon at the top of the reply/add comment page allows for full size photos to be uploaded directly to the post, the photo is automatically resized in the post. The photo uploaded as you have shown is often too small to see detailsin any clarity.
The photo below was directly uploaded from my computer to this post. The screw is not in this picture, it is just an example of what can be uploaded.
