Old Dec 20, 2016 | 06:35 PM
onehundred80
Default Re: Radio and climate fan work without key, normal?
I have not read that the coolant pump runs when in that mode. Where is that written?
When I bought the car, the previous owner told me that mode was for when you parked the car after using the AC, it will dry out the evaporator area to prevent musty odors. I do use it that way and so far no smells at all.
James
Page 115 of the 2004 Owners Manual.
Residual Engine Heat Utilization (REST)
With the engine switched off, it is possible to
continue heating the interior for a short while.
Air volume is controlled automatically. Select a
temperature for each side of the passenger
compartment. Set the air distribution control switch to
the desired position.
To select, turn the key in the ignition switch to the ACC
or the OFF/LOCK position or remove. Press the recirculation
button. The indicator light in the button illuminates.
This function selection will not activate if the
battery charge level is insufficient.
To cancel, press the recirculation button. The indicator
light in the button goes out. The system will automatically
shut off if you turn the key in the ignition switch to
the ON/RUN position, after approximately 30 minutes,
or if the battery voltage drops.
