Old Dec 21, 2016 | 09:37 AM
onehundred80
Default Re: Headlight Adjustment
There are 3 'normal' upgrade options for the NA's, in this order :
1. Single CAI ( Cold Air Intake ) from NeedsWings.
2. 74 mm throttle body from eBay, here, or a junk yard ( car-part.com )
3. Eurocharged tune from eurocharged.com - this remaps the PTCM to utilize the above two to greater advantage. expect 25 - 35 more HP, better response, more torque and better economy.
You missed out on the larger MAF housing. CLICK
Also the Mercedes engine cover instead of the NW intake is a cheaper option and probably is just as good or nearly as good. CLICK
Your 25 hp is probably max on either mod and it will be at the crank not the wheels. Euro claims 18 hp at the crank if my memory serves me.
At the wheels 200 hp would be hard to obtain, 195 is probably the max
