Old Dec 27, 2016 | 08:17 PM
pizzaguy
Default Re: Electric radiator fan stays on
Originally Posted by kcoolwillis
Hello everyone,
I have a 2005 conv. I recently had an issue with a battery drain. I was constantly jumping it every morning before work. With process of elimination, I found it to be a the new radio I had put in the week before. For the moment I pulled the new radio out and put in the original radio. The battery drain stopped. The problem I'm having for some reason, is the radiator fan turns on and will not shut off unless I turn the ignition off. Also my A/C has no power, the clutch does not engage. I checked all of the fuses and all are good. Has anyone had a similar situation. Thanks Kevin. New Member
After you start the car, do you have a little yellow light on in the left side of the instrument panel that looks like a little radiator?
