Old Dec 29, 2016 | 02:42 PM
  #96 (permalink)
djohn14296's Avatar
djohn14296
Angry Re: Car Alarm Keeps going off!!! Dead Battery!?!
To answer your question, yes you can disconnect the alarm module without effecting anything else.
( you have to remove the wiper arms and the plastic cowling to get to it however )
HOWEVER ! I have never heard of the alarm module causing the lights to flash, it only has 3 wires running to it :
1. a ground wire
2. a 12v always hot wire.
3. a signal wire that tells it to holler.
I would suspect the CLPM in the trunk as the culprit ( along with 180 ),
might try just disconnecting the 3 electrical plugs to it, spray all with contact cleaner,
let it dry then reconnect.
OK George, I decided to cut though the trunk insulation and dig out the Unit (CLPM), it looks bone dry and has never seen the 1st drop of water, clean as the day it was manufactured. Should I still get some contact cleaner and put a little dab of dialectic grease? Enclosed some pictures.
Next step start checking switches in the doors, hood, & trunk? I'm not good with electrical things, chuk, any chance you might be? I'm also a crappy picture taker.
