Old Jan 6, 2017 | 11:08 AM
kuratsunade's Avatar
kuratsunade
Default Re: Radar Detector Hardwiring / Head Unit / Odds & Ends
Originally Posted by Ralph289
Did this installations and have no turn signals any ideas why ?? Radar detector is working fine .
If you did a Fuse Tap, Both fuses should be inserted into the tap to make everything working. Insert only one will make only one side (original or tapped) work.
If you have both in place and still not working, check the fuse.
