Old Jan 6, 2017 | 11:32 AM
Ralph289's Avatar
Ralph289
Default Re: Radar Detector Hardwiring / Head Unit / Odds & Ends
Originally Posted by kuratsunade
If you did a Fuse Tap, Both fuses should be inserted into the tap to make everything working. Insert only one will make only one side (original or tapped) work.
If you have both in place and still not working, check the fuse.
That was the problem only had one fuse in......Thank You !
